API Documentation
This is the documentation for the available API endpoints, which are built around the REST architecture. All the API endpoints will return a JSON response with the standard HTTP response codes and need a Bearer Authentication via an API Key.
Authentication
All the API endpoints require an API key sent by the Bearer Authentication method.
curl --request GET \
--url 'https://dlk.vwj.temporary.site/website_8c766510/api/{endpoint}' \
--header 'Authorization: Bearer {api_key}' \
All API endpoint results work with the UTC timezone unless specified otherwise.
